1998 PATHFINDER DISTRIBUTOR & CHECK ENGINE LIGHT
Old Oct 12, 2007 | 09:03 PM
njtuna's Avatar
Default 1998 PATHFINDER DISTRIBUTOR & CHECK ENGINE LIGHT
recently took my pathfinder in due to hesitaion and rpm fluctuations while driving. diagnostic computer said distributor was bad. we installed a used distributor ourselves. everything working fine, except check engine light is now on. could changing the distributor have triggered the check enging light? if so, how can i turn it off? thanks
Old Oct 15, 2007 | 06:23 PM
njtuna's Avatar
Default RE: 1998 PATHFINDER DISTRIBUTOR & CHECK ENGINE LIGHT
car is ok. took it to autzone and they hooked it up to the computer. it said it was a problem with timing belt, and a couple of other things. the light went on when we were adjusting the distributor
302lvr
Mar 27, 2008 02:00 PM
jcosand
Jan 3, 2006 08:04 PM
Xtina
Dec 15, 2005 12:57 AM
Pod97654
5
Sep 6, 2005 05:59 PM
