98 Nissan Pathfinder rough idle p0300 p0325 p0301 codes vg33 check engine light
Old Jun 30, 2007 | 06:54 PM
melty's Avatar
Default 98 Nissan Pathfinder rough idle p0300 p0325 p0301 codes vg33 check engine light
My 98 pathfinder check engine light came on and the engine was running rough. I went to Auto
Zone to get the OBDII error codes: P0300 Multi Cylinder misfire, P0301 Cylinder one, P0325
Knock sensor. They reccomened a tune up, which it needed: Plugs OEM, Plug wires, Distribitor
cap and rotor, Fuel filter, Air filter, Oil Change and to put some Lucas injector cleaner in
the fuel tank. These would be the first steps to resolve the the P0300 & P0301 codes. I
installed these parts and the check engine light went off for a while, but came back on. They
said the P0325 Knock Sensor code is usually triggered by other problems with the engine, such
as the P0300 or P0301-6. The next step was to check the injectors, you can
have the injectors power cleaned by a shop through the fuel rail for about 60.00 to 150.00.
You can check the injector function by disconnecting the wire clip on the top injector while
the engine is idling, the engine should stumble or run worse than when it is connected. When
I disconnected cylinder 1 on my engine the engine ran the same as if it where connected, so I
replaced the injector on cylinder 1 (P0301)and the problem was solved.
Old Jul 4, 2007 | 08:22 PM
Dvo's Avatar
Dvo
Default RE: 98 Nissan Pathfinder rough idle p0300 p0325 p0301 codes vg33 check engine light
Good work; thanks for the detailed info.
Old Nov 1, 2007 | 09:22 AM
melty's Avatar
p0300 p0301 p0302 p0303 p0304 p0305 p0306, p0325
Quick fix: try BG 44KĀ® Power Enhancer full 11oz can/bottle to 1/2 a tank of gas. WORKS!
msfoster
Nissan Xterra
Sep 11, 2011 06:32 PM
xr3dpill
Nissan Of Japan Other Models
Oct 4, 2009 06:58 AM
jschmitz
Jun 9, 2007 02:36 PM
atomicdog
Feb 18, 2007 09:24 PM
Ranz1
Nov 30, 2005 12:54 PM
