2007 Pathfinder Bose DVD
RE: 2007 Pathfinder Bose DVD
I had this problem on another vehicle I had. The solution had to do with the way I was burning the CD. Some burning software will ask you if this is a data CD or a Music CD. You need to select the Music CD. With the Music CD, when you get done burning your music, the program does a "finish". It will tell you that you can't add anymore songs once it completes. When you burn a data CD, there is no finish. So when you put the CD in your player, the player doesn't recognize it as a music CD. If your burning program doesn't give you an option to specifically burn a music CD, there usually is a setting to do a finish after you get done burning your music. Try this and see what happens.
Chris
Sacramento, CA
Chris
Sacramento, CA
RobAtlanta
Audio/Visual Electronics
11-29-2005 05:58 PM
