Erratic blower air volume output 2015 Pathfinder
Old Oct 23, 2019 | 07:09 AM
Macleang's Avatar
Default Erratic blower air volume output 2015 Pathfinder
Erratic blower air volume output 2015 Pathfinder. On initially starting, HVAC system works normally in both a/c and heating modes. After a period of time from minutes to hours, air volume output from all vents will quickly reduce to almost nothing with no real change in blower motor sound. Reduced air flow affects aĺl vent modes, recirc and fresh air, as well as dual and single modes. Blower appears to run appropriate to blower setting, just no airflow from vents. Output from rear passenger system similarly affected. Nissan mechanic has spent hours trying to diagnose. Cabin filter replaced, intakes checked for obstructions and blower motor removed and checked. Malfuntion will continue until car is turned off and allowed to sit for a long period. (Of note, issue first appeared some weeks after repair work completed for large stone impact to underside which caused significant damage to frame, oil pan, a/c leak, drive train etc.) Does anyone have any idea what could be causing this?
Old Mar 7, 2020 | 07:40 PM
Brian Wistisen's Avatar
We have the exact same problem on our 2015 Nissan Pathfinder. It's a piece of junk. The air will work when you're driving around town for a few minutes at slower speeds. But as soon as you get on the freeway or drive longer distances, the airflow completely shuts down. It makes no sense.
Old Mar 2, 2021 | 03:52 AM
SuperFly's Avatar
Not bad. I've been working with this topic for several years now, and I've learned about all the advantages and disadvantages of my profession(HVAC master), I think. My experience of three years is not enough to call me a master, but I definitely know a lot about my work and your issue. You can ask me anything you need. In order to be called a master, I need to take courses and learn more about all the subtleties of schemes and details. I need to develop so that I have a constant flow of customers, otherwise I risk being left with nothing and fixing air conditioners only in my home. Of course, this is not bad, but it does not bring any prosperity
Tbirdbooboo
Mar 2, 2021 03:35 AM
jostermeyer
Jan 4, 2013 10:57 AM
sunzoon
Nov 3, 2007 08:37 AM
rokfor
Jul 1, 2006 05:01 PM
alan911
Apr 25, 2006 07:54 PM
