Help! Rough Starting Pathfinder
Old Oct 6, 2023 | 03:24 AM
Pepo1's Avatar
Default Help! Rough Starting Pathfinder
97 Nissan Terrano/Pathfinder 3.2 diesel. Started doing this hesitating, bucking and jerking thing at startup. Doesn't do it all the time. Usually when cold. Once started, the engine runs fine. Battery is fine. Suspect a starter motor or solenoid. There is no grinding or gnashing noise, just this kind of hiccup as it turns over. Any ideas gladly welcomed before I spend $400 on a new starter motor. Cheers!
Old Nov 12, 2023 | 03:21 AM
Gazzer83's Avatar
Check all powers and especially the grounds. They have a bad habbit of going loose and getting corroded causing bad grounds.
Priceless
Nov 6, 2017 07:16 PM
rokfor
Mar 8, 2007 12:09 AM
Cooldork87
Feb 17, 2007 04:57 AM
90pk954x401path
Nov 18, 2005 10:56 AM
autonoz
Sep 29, 2005 02:05 AM
