I Can't locate the coolant drain plugs on the block, help!
Old Aug 5, 2009 | 01:32 PM
bolttp's Avatar
Question I Can't locate the coolant drain plugs on the block, help!
I have a 2001 Nissan Pathfinder (2WD), and I'm unable to locate the two drain plugs on the engine block. One is located on the right side of the cylinder block and the other is located by the water pump. I have a diagram showing where they are, but I don't see them. I even had a mechanic try to locate them and was unsecessful.
stallion
Jan 21, 2009 09:26 PM
jeneric27
Jun 20, 2007 12:23 PM
pokageek
Dec 6, 2005 12:55 AM
khuevo
Aug 24, 2005 04:13 PM
grgordon11
Aug 3, 2005 06:00 PM
