marker lights not working
Old Mar 28, 2007 | 01:24 PM
sideways4m's Avatar
Default marker lights not working
hello, on my 95' pathfinder ebay jewel the marker lamps and dash lights don't work. all other lights work but those. does anyone know what the problem may be? thanks, noah
Old Mar 29, 2007 | 12:41 PM
Default RE: marker lights not working
check your fuses first it sounds like you might of blown a fuse. check the fuse box thats by the drivers side kick panel and the one under the hood.
Old Mar 29, 2007 | 06:08 PM
sideways4m's Avatar
yea i checked the fuses and looked for broken wires. no power at any bulb sockets.? thanks though.
Old Mar 29, 2007 | 09:47 PM
did you check the fuses with an ohm meter cause ive seen fuses that looked fine but where burned open, also if the fuses are good check for battery voltage at the fuse that supplies power to the marker lights and dash lights and make sure you have power there and also check your fuse box grounds. let me know if you have voltage and good grounds.
Old Apr 1, 2007 | 01:11 AM
thunder's Avatar
i replaced the headlight switch on my 90 and the dimmer switch and everything works fine
3xbrokejoke
Nissan Xterra
Mar 15, 2008 03:37 PM
79SR280ZX
Feb 3, 2008 02:13 PM
red_bike
Aug 31, 2007 03:17 PM
buddah
Oct 31, 2006 03:59 AM
jerseyparts
Nissan 350Z / Fairlady
Aug 30, 2006 11:43 PM
