STUCK PLUG
Old Aug 12, 2008 | 11:13 AM
BRETT53199's Avatar
Default STUCK PLUG
I bought my '99 Pathfinder in December. I recently changed the plugs (5) of them and I am unable to get the middle one on the top out. It has stuff hardened around the plug nut and I can't get a socket on it.Anyone have this problem? How did you get it out? I’ve scraped around it but that hasn’t done any good. Help would be great. THANKS Sorry for the lame description, I’m not good at this kind of stuff but it save money so I try to do it myself.
Old Aug 16, 2008 | 03:04 PM
89pathfinderxev6's Avatar
Default RE: STUCK PLUG
hay it did that on my 89 pathfinder try some pennatrating catalist like pb let it sit then turn it slowly if not out in the first day repet for a wile this may work
Old Aug 16, 2008 | 03:07 PM
Default RE: STUCK PLUG removal instructions
Answer
Stuck plug!!! Oh baby, what a treat.
"These here plugs can go 100,000 miles without changing" the car salesman and manufacturers boost. Just try to get em out. They should warranty them for that long.
Anyways, if you change them every 30,000 miles and put a little anti-seize on the end of the threads, you won't have this problem. They get seized from heat, corrosion, overtightening and age.
Hopefully, it won't break when you try. I continually soak it in a high quality penetrating fluid. And turn it out a little and back in a little, back out a little and back in a little. Eventually, with a little skill you might get it without breaking. You may end up pulling the threads out of the head, but you can insert a heli-coil and get your new plug back in. May end up pulling the head if it doesn't go so well. ROTS A RUCK
Answer
I recommend you go out and buy some Break Away and let it soak for about 15 to 20 min. Then work it back and forth until it comes loose
Old Aug 16, 2008 | 03:09 PM
Let me know if it helps theres more in wiki anwsers
shipkdc
Nov 25, 2006 12:59 PM
craig01kc
Oct 16, 2006 07:58 PM
shipkdc
Sep 17, 2006 02:32 PM
phillydutch
Sep 9, 2006 06:29 PM
tjhanes
Jan 3, 2006 07:11 PM
