Blower motor not working in cold weather?
Old Dec 12, 2017 | 06:22 AM
Muintir's Avatar
Default Blower motor not working in cold weather?
I bought this van last spring and the blower motor never worked so I recently replaced it about a month back and everything was working great. Weird part is when I cut the ends off the old blower motor and touched them to the battery the motor worked perfectly. We had our first snowfall and real temp drop 2 days ago and the blower motor would not work at all. However once the car drove for awhile it would turn on and start working. Every now and then it would do something weird where it would slightly blow air like the setting was turned down but then it would start blowing normally. Yesterday the same thing happened where the blower motor would not work at all until the car was driven for about 30 minutes. I am at a loss as the blower motor was just replaced. Its not the resistor so im at a loss on whats causing this.
Thanks in advance!
Old Nov 9, 2021 | 01:39 PM
ccommcomm's Avatar
We have a nissan sentra that has a similar issue. The blower will not work from time to time. If I hit the dashboard it will fix it most of the time.
Did you ever find a solution to the problem? I think it is an electrical short somewhere in the dash. It sounds like yours might be similiar. Maybe a wire has rubbed off the insulation and as it heats up and everything expands. it stops touching whatever it is causing the short.
Cree454
Nissan Quest
Aug 7, 2021 04:26 AM
jostermeyer
Jan 4, 2013 10:57 AM
MEWERS
Nissan Murano
Jan 12, 2009 09:01 PM
griff83
Oct 26, 2007 04:48 PM
rokfor
Jul 1, 2006 05:01 PM
