2000 sentra Po171 code
Old Jan 3, 2007 | 10:01 PM
77ford's Avatar
Default 2000 sentra Po171 code
Hi, I'm trying to help out a friend that has a 2000 nissan sentra with I believe it is a 18 motor( i didn't write down the engine size but I do remember it has 16 valves) with 81,000 miles. It has only the p0171 code. Is there anything specfiic to these types of cars that cause this code. I have a scan tool but was unable to get a good connection, so until I can get a extension cable to plug in to it I can't get any MAF or O2 sensor data.
Is there a fitting on the fuel rail tocheck the fuel pressure. If so what is the pressure range suppose to be?
My friend also said it is hard to fill the tank up with gas and I found a TSB (NTB00038) about this but it didn't give and specifics. Is there a way to fix this or is this not a big deal (only makes it slower to fill tank and doesn't effect anything else).
Old Jan 6, 2007 | 07:10 PM
77ford's Avatar
Default RE: 2000 sentra Po171 code
Well I found out about the fuel pressure and how to test it. Need a tee fitting to attach the fuel pressure tester.
Old Aug 4, 2008 | 03:21 PM
chuckie902's Avatar
[:@]i got the same code on my 2001 gxe............ fuel rail 1 lean but it only has one fuel rail?????
and no inline filter????? only intank, so what could cause this code to pop???? poor fuel presure?? bad pump or gloged line??
man these ones suck i just replaced the coil pack last week and now this!!
Emil
Aug 20, 2012 03:48 AM
echill
Aug 30, 2009 07:44 PM
redsoxfan
Apr 30, 2007 12:18 AM
joe7583
Aug 7, 2006 10:19 PM
segato13
Jun 12, 2006 04:33 AM
