BUILDING A 1.6
I NEED TO KNOW WHAT ENGINE CONPONENTS I COULD USE IN MY 1.6 SENTRA. MY GOAL IS TO MAKE A N/A ENGINE AND HAVE AROUND 200 HP.
RE: BUILDING A 1.6
ORIGINAL: SUNNY1.6 I NEED TO KNOW WHAT ENGINE CONPONENTS I COULD USE IN MY 1.6 SENTRA. MY GOAL IS TO MAKE A N/A ENGINE AND HAVE AROUND 200 HP. They make around 130whp with alot of mods. |
RE: BUILDING A 1.6
Hot Shot makes a turbo kit for the GA16 motor it says it will add 80 HPs which will get almost there and thats with a stock motor. upgade the injectors and add turbo pistons and a good set of cams you should be able to up the boost and get any where from 200HP to 300HP
RE: BUILDING A 1.6
ORIGINAL: hendricks152003 Hot Shot makes a turbo kit for the GA16 motor it says it will add 80 HPs which will get almost there and thats with a stock motor. upgade the injectors and add turbo pistons and a good set of cams you should be able to up the boost and get any where from 200HP to 300HP ORIGINAL: SUNNY1.6 MY GOAL IS TO MAKE A N/A ENGINE AND HAVE AROUND 200 HP. |
RE: BUILDING A 1.6
It's possible ... but not worth it .... I would reccomend investing in a SR20 motor... much better platform to build on.
RE: BUILDING A 1.6
ORIGINAL: Burnnout It's possible ... but not worth it .... I would reccomend investing in a SR20 motor... much better platform to build on. If he wants a good N/A street set up, get a JDM 10:1 motor with C series cams form JWT, Gen6 header, 3 inch exhaust, UR pulleys, 19* timing, CAI and he'll run low 14's all day. And, for higher compression get SR16VE pistons which i think make 12.5:1 C/R |
RE: BUILDING A 1.6
Well going N/A on a nissan motor in general isn't the way to go .... for big power out of a 4 banger get a turbo.:D
RE: BUILDING A 1.6
ORIGINAL: Burnnout Well going N/A on a nissan motor in general isn't the way to go .... for big power out of a 4 banger get a turbo.:D well, i wouldnt say its not the way to go, cause the VVL motors are great for N/A setups, but most people like to boost there Nissans. |
RE: BUILDING A 1.6
VVL motors are decent.... but on the average a turbo will deliver more power, faster.
RE: BUILDING A 1.6
ORIGINAL: Burnnout VVL motors are decent.... but on the average a turbo will deliver more power, faster. VVL motors are more reliable than turbo motors, Some VVL's are running just as fast as DE-Ts I forgot who is was but i seen on another forum VVL motors running high 12's, either way you cant loose. |
