Exhaust Leak / Noise - 05 Sentra 1.8
Old Dec 31, 2009 | 11:13 AM
rickl's Avatar
Default Exhaust Leak / Noise - 05 Sentra 1.8
My 05 Sentra has 118k miles and the 1.8L engine. The engine recently got much noisier and it sounds like there may be an exhaust leak. The exhaust noise is coming from the front of the car. It is not noticeable when the engine is idling, but when accelerating, the engine sounds much louder than it should be. I plan to get the car in the air this weekend and check for exhaust leaks.
Has anyone experienced this before? If so, where is the most likely place I should look for the exhaust leak?
Thanks...Rick
Old Jan 1, 2010 | 05:44 PM
rickl's Avatar
So I have the car on stands and removed upper and lower heat shields from the exhaust manifold. I see no evidence of an exhaust leak. I started the car and ran my hand over all areas where I thought there may be a leak, but found nothing. Again, the noise is most noticeable when accelerating and seems to originate from the front (passenger side) of the car.
Any ideas? Thanks...Rick
Old Jan 2, 2010 | 01:37 PM
rickl's Avatar
I'm starting to think the noise is not caused by an exhaust leak. The noise is a knocking or slapping sound come from the belts side of the engine and is only noticeable upon acceleration. At idle, the engine sounds perfect. Could it be the timing chain with only 118k miles?
Advice anyone? Thanks...Rick
Old Jan 25, 2011 | 07:46 PM
full house's Avatar
hmm, how old is your car? I bet its a used one... maybe the engine being installed is not meant for it reason why the noise occur... what kind of engine you are using?
Old Jan 31, 2011 | 10:02 PM
DiagnosticDDT's Avatar
Check the exhaust manifold for leaks. It probably have a bad manifold gasket, or a crack in the manifold itself.
Old Feb 15, 2011 | 03:33 PM
champ's Avatar
Just a note to thank the workplace of Jeffrey Cancilla for your kindness and expertise on my bankruptcy. I had a fantastic encounter with Mr. Jeffrey Cancilla with my loan modification. Jeffrey Cancilla took care of me from the starting from the procedure, and gave me everything I asked for. A Highly recommend Atty. Jeffrey Cancilla as your lawyer. We've superb service with them. I thank my friend that she recommended Atty. Jeffrey Cancilla to us, Bottom line, we are happy for the service We now have from them! Thanks SO MUCH!!!
rennzxterra
May 30, 2007 12:27 PM
rennzxterra
May 30, 2007 07:42 AM
Nappers
Apr 29, 2006 06:27 PM
Munchkin1
Mar 19, 2006 05:45 AM
frank21_1981
Nov 7, 2005 06:12 PM
