help asap, replacing outter cv boots
Old Feb 25, 2006 | 12:50 PM
1997nissansentra's Avatar
Default help asap, replacing outter cv boots
hello everyone, i jsut got a 97 nissan sentra gxe, 4 door auto...my outter cv boots are ripped and im in the process of replacing them...right not im stuck because im not sure how to put on the new boot...im doing the passenger side right now...and im not sure how the part on the end of the drivshaft comes off so i can slide the new boot on, shoulda thought about that before i started tearing things apart, but please help me asap. thanks in advance!
Old Feb 27, 2006 | 08:20 PM
Default RE: help asap, replacing outter cv boots
what you do is put the axle in a vice and remove the old torn boot and turn the out cv joint and you should be able to take a hammer and hit the joint and it should pop right off with a couple of hits then you install the new boot the smaller end first and slide the cv joint back on and tap it and then put the new grease in the boot and finish installing the bigger end of the boot on and tighten the straps and your good to go. the inner boot comes right off when you remove the boot. well good luck. you could also just remove both axles and take them to an axle shop to reboot them for you for a resonible price. well good luck.
beau1
Jul 31, 2010 03:22 AM
pr0lab
Jul 30, 2007 09:19 PM
fairmanz
Nissan 300zx
Jan 9, 2007 11:49 AM
jnr_chin
Nissan Skyline
Dec 31, 2006 02:25 AM
jdmcivic1999
Oct 11, 2006 01:38 AM
