Help with Igniton Switch bypass
Hi everyone,
I have a 1995 Nissan Sentra Sedan that will not start. Had the Alternator checked, starter, and battery. The car acts as though there is no battery even in it when ignition key is turned. All accesories work with key turned to on position. I am thinking that it is the switch and need to know how or even if a switch can be hooked up to a push button or toggle switch to allow power to the starter when needed. I had this set up in an old car I bought years ago and it worked perfect. The sentra has been very good to me and I believe it still has more to give. Thanks for any help with this. |
Hi everyone, I have a 1995 Nissan Sentra Sedan that will not start. Had the Alternator checked, starter, and battery. The car acts as though there is no battery even in it when ignition key is turned. All accesories work with key turned to on position. I am thinking that it is the switch and need to know how or even if a switch can be hooked up to a push button or toggle switch to allow power to the starter when needed. I had this set up in an old car I bought years ago and it worked perfect. The sentra has been very good to me and I believe it still has more to give. Thanks for any help with this. |
Originally Posted by full house
(Post 13885)
How about the engine?Did you check it?
After doing some reading I found where someone with the same problem also had problems with a heater motor. A poster said that the a problematic heater motor can draw too much power through the ignition switch, causing it to burn out. I also had heater blower motor issues prior to this. |
| All times are GMT -5. The time now is 05:45 AM. |
