OIL CHANGES
Old Aug 30, 2005 | 02:12 PM
ROBERT's Avatar
Default OIL CHANGES
DEAR FORUM,
I HAVE A PERPLEXING QUESTION. SINCE I DO NOT PUT MUCH MILEAGE ON MY SENTRA CURRENTLY, (ONLY 800MI SINCE LAST OIL AND FILTER IN JUNE 2005) OTHER THAN THE MANUAL, HOW WOULD YOU PRO'S RECOMMEND THE OIL CHANGE BY TIME? CAN I GO UP TO 5 OR 6 MONTHS? ( THE OIL STILL LOOKS LIKE NEW SINCE THE LAST CHANGE IN JUNE).
THANK YOU!![]
Old Sep 3, 2005 | 10:18 PM
toidsworth's Avatar
Default RE: OIL CHANGES
I would say that if you don't put 5000 miles on it in 6 months change it anyway. Condensation puts water in the oil and if you at least drive it long enough for the water to burn off you will be ok.
Old Sep 14, 2005 | 04:22 PM
LIUSPEED's Avatar
no matter what car you have it always good to change your oil every 3 months or every 3000 miles.
Old Sep 22, 2005 | 11:34 AM
toidsworth's Avatar
ORIGINAL: LIUSPEED
Not so. When you change oil every 3000 miles you are doing about twice as many dry starts over the life of the engine than you would at 5000 mile intervals. On the Sentra due ro the filter orientation you can't put much oil in it at all to lessen the dry startup damage. If you want to send your car into it's grave keep changing at 3000 mile intervals.
You are living in the past all conventional motor oils will live way past 5000 miles. My wife works at a lab that does oil analysis and most motor oil sent in at 5000 miles still is well in grade and low in acids. It's your money and engine life.
Old Oct 1, 2005 | 02:04 AM
sporkhey's Avatar
I got a question for this Oil topic -- I want to change my oil as least as possible -- what kinda oil should i use - i dont care to change to full synthetic - whats a good oil to use - Mobil oil says 15000 miles ??? gimme some advice? thanks
Old Oct 4, 2005 | 01:04 PM
toidsworth's Avatar
ORIGINAL: sporkhey
Amsoil claims 25,000 mile oil changes and it is about as expensive as the Mobil 1 extended life oil. If I were you I would use Amsoil and Amsoil oil filters too and I would change it at 15,000 miles not 25,000.
beimoting
Jul 4, 2012 01:33 AM
sporkhey
May 1, 2006 11:21 AM
NxtremeSER
Feb 14, 2006 05:13 PM
lscottp
Apr 29, 2005 05:45 AM
lscottp
Apr 20, 2005 11:21 AM
