skline droping boost
i am running a rb20det i have
stock intercooler
turbo x s boost controller
hks waste gate
garret turbo 70 front and a smaller back
when i go on boost in any gear the boost goes up and then goes back on vacuum until i change the gear
the point were the car is just about to start using the power it cuts back.
i have checked for leaks on the intercooler, the piping and found no leaks
help me please i dont know if its the waste gate the timing or if the car has a boost sensor that cutting it back
stock intercooler
hks waste gate
RE: skline droping boost
What are you using to control the air/fuel mix ? .... I'm no skyline expert... but I'm assuming the air/fuel mix is controlled by the PCM on a stocker.....which means if you added a boost controller and wastegate and bumped up the boost the PCM is seeing that and pulling timing because it's seeing that you are about to overboost.
