Nissan Xterra The Xterra offers a more compact alternative to the Pathfinder, without compromising interior size, and with the optional supercharged engine, it is not all bark and no bite.
Problem fueling 2001 Xterra
Old Oct 9, 2007 | 10:35 AM
toddhol's Avatar
Default Problem fueling 2001 Xterra
I purchased a used 2001 Xterra with 100K miles. For about the last month, every time I try to fuel it up, the pump shuts off every few seconds. I have tried different gas stations, different pumps at the same station, different angles for the hose, but nothing seems to work. I am interested in finding out what might be causing this problem, how to fix it, and if there has been a recall related to this problem.
Thanks,
Todd
Old Oct 12, 2007 | 12:12 PM
maxl's Avatar
Default RE: Problem fueling 2001 Xterra
i have 2001 XTerra and, yes there was a recall for the shut-off valve on the fuel tank.
The problem was, it would't shut off fuel pump at the station. Check if yours went throught a recall.
Go to nearest Nissan dealeship, they might trace it for you.
Best luck.
Old Nov 6, 2007 | 02:47 PM
marcbeaudin's Avatar
i have the same problem with my 2002 xterra did you ever find out what was wrong with you fuel tank?
Old Nov 8, 2007 | 11:59 AM
toddhol's Avatar
You are the first person I have found who has experienced the same problem with the fuel tank. I contacted several dealerships and a number of independent mechanics, none of which had ever heard of this type of problem. This left me thinking that maybe there is some foreign object crammed into the fuel intake. Now I don't know what to think......
maggiesmim
May 18, 2015 08:25 AM
May 8, 2015 09:52 AM
kathnp
Nissan Xterra
Oct 16, 2007 08:41 PM
Darrell
Nov 12, 2006 10:20 PM
flablonde
Jun 18, 2006 09:47 PM
