Nissan Xterra The Xterra offers a more compact alternative to the Pathfinder, without compromising interior size, and with the optional supercharged engine, it is not all bark and no bite.
water pump?
Old Oct 28, 2007 | 11:32 PM
caraudiopro's Avatar
Default water pump?
I have a 2003 Xterra 3.3L non-S/C. Its got a funny whine. Its a low hum when idle, then turns to a whine when you rev the motor. I already took it apart once thinking it was the timing belt, I re-adjusted it, no change. So I'm pretty sure its the water pump but would like to make sure befor I repleace it.
So from my understanding the water pump runs off the same pulley/belt as the fan. So if I take off the belt and start it, and the whine is still there, then its not the water pump correct?
Then it could be any of the other pulley's, which I would check in the same way. Then my last hope is the timing belt tensioner.
Any input on this would be greatly apreciated. Thank you
jdydvd
Oct 4, 2006 10:50 AM
purple
Jul 1, 2006 09:30 PM
purple
May 11, 2006 08:02 PM
purple
May 3, 2006 05:48 PM
Tarkus697
Dec 20, 2005 05:32 PM
