I need Help!!!
when I first got it, it did not work I pay $600 for it all I had to do is put new battery cables, new battery and change some fuses that was it! Well one day the car alarm went of and I don’t have the remote so I unhooked the battery. This would keep happing so I had to keep unhooked from the battery well I went out one day to change the oil and I could not get it to crank the battery is good. it just clicks well I found out that the factory alarm had disabled the motor. I finely found out how to reset it. and now the motor turns over but will not start. What could calls this?
Is it possible to remove the alarm cause it keeps going off and so I don’t have to wory about it disabling the motor.
Thanks
Thanks
