02 max transmission
Old Dec 21, 2006 | 09:47 PM
parceroreal's Avatar
Default 02 max transmission
02 max SE Auto Trans w/ 4,500 miles...
transmission will shift hard between 1st and 2nd, normal to 3rd...will not shift to 4th
replaced fluid w/ Nissan trans. fluid... 6qts.
is there a lock up switch of some sort to look at...any adjustments to be made...?
my shift lock release is broken, soi don't have to press the brake to move the shifter from P to R to N to D 3-2-1
Can anyone tell me what the Neutral Safety Switch is?
Old Dec 22, 2006 | 07:53 PM
Fraggle2005's Avatar
Default RE: 02 max transmission
ORIGINAL: parceroreal
my shift lock release is broken, so i don't have to press the brake to move the shifter from P to R to N to D 3-2-1
Well I would check the dash to see if the o/d off lamp is on. If it is push the o/s switch. Neutral safety switch prevents the car from being started in gear.
joebugle
Nov 29, 2006 03:59 AM
jmart2221
Apr 23, 2006 08:53 PM
ntxmotorsports
Aug 5, 2005 04:51 PM
marketapex
Jul 30, 2005 06:16 PM
stevemcintosh
Jun 13, 2005 05:57 PM
