dash guages
Old May 9, 2006 | 07:48 AM
Duke9088's Avatar
Default dash guages
My 1988 Pulsar dash guages do not work most of the time. Only the gas guage works periodically. How do i go about fixingthis problem?
Old May 14, 2006 | 06:41 PM
handyandhandsome's Avatar
Default RE: dash guages
do all the other dash lights (ie speedometer) work?
Old May 15, 2006 | 07:16 AM
Duke9088's Avatar
Yes the speedometer works, it's the tach, and oil pressure guages that don't.
Old May 15, 2006 | 12:16 PM
OK...that is good that the speedometer has lights as this is an important gauge. I'm not familiar with your car interior. So is the tach bundled with the oil pressure other gauges or is a separate instrument like the speedometer?
Old May 19, 2006 | 10:06 PM
Duke9088's Avatar
Ok, the guages are, tach on the left, speedometer on the right, the temp guage on the top in the middle, and the gas guage in the middle bottom. The speedometer is theonly guage that works. The gas guage only works periodically, and then almost always reads 1/4 tank.
Old May 23, 2006 | 06:46 PM
speedometer is working as this has a direct mechanical connection to the transmission via a rotating cable. The other gauges most likley transmit a small electrical signal from a transmitter (such as a pressure transmitter for oil pressure) to the gauge. As such, I would check the fusible links to make sure that none have a burned out wire; you owner's manual should show you were they are located and which provide protection from overcurent to each dash guage.
Xterror
Nissan Xterra
Dec 13, 2007 07:03 AM
Duke9088
May 11, 2006 10:47 PM
beerguy
Oct 28, 2005 11:25 PM
Frank
Nissan 300zx
Jun 3, 2005 05:51 PM
jvvuurw
Jun 2, 2005 02:21 PM
