Needing some Tech Help...
Old Jun 19, 2007 | 11:33 AM
drahill's Avatar
Default Needing some Tech Help...
Bought anew (used) '01 Altima for the newest driver in the family. Took itto the car wash yesterday; cleaned it inside & out. Washed engine compartment with degreaser, then Hi-Pressure wash and rinse. Tried to avoid wetting obvious trouble-spots (distributor, alternator, fuel rail, etc.), but apparently I got something wet that I shouldn't have. Car wouldn't start & run. Cranked & cranked. When it DID start, ran terribly rough. Dried inside of the distributor, which had a minute amount of moisture in it. Same thing, cranked & cranked. The longer I left it to sit, the more success I'd have at getting it started, but would run very rough, and die if I tried to drive it. Left it at the car wash for two hours or so, went back, started right up sounded okay. Drove it 4-5 blocks to get it home, ran like crap; died 100 yds from driveway--pushed it home. Let it sit overnight. Started right up this morning; sounded perfectly normal at idle, & when revved-upto a higher RPMs. Drove it; ran like crap and died again. What's wrong, & how can I fix it?
Appreciative of any sound advice,
drahill
Old Jun 19, 2007 | 12:22 PM
Default RE: Needing some Tech Help...
pull the spark plug wires off the spark plugs and get all that water out of there that is causing a misfire cause of all the water around your spark plugs. seen it a million times out of our detail department at the dealership.
Old Jun 19, 2007 | 01:55 PM
drahill's Avatar
Thank you! That did the trick. Your advise is much appreciated
Thanks a Million!,
drahill
Old Jun 19, 2007 | 02:02 PM
no problem glad that i could help
MadSuRfEr
Jun 27, 2006 08:16 PM
inder
Apr 28, 2006 11:43 AM
gruberhome
Jan 23, 2006 09:07 AM
Cuddly
Nissan Skyline
Sep 12, 2005 10:20 AM
