Transmission Clutch Noise
Old Jul 5, 2006 | 11:37 PM
92pathfinder's Avatar
Default Transmission Clutch Noise
I have a 92 4x4 Pathfinder with about 120,000 miles on it and recently the transmission or clutch has started making a noise when engaging/disengaging the clutch. I was told by a shop that it was the throw out bearing. The transmission still pulls fine and does not slip at all. Actually just pulled a trailer over a seven hour trip with no problems other than the noise. The hydraulic clutch fluid level was a little low but I topped that off. Would it be anything to do with the hydraulic clutch stuff? Thanks.
Old Jul 6, 2006 | 03:18 PM
handyandhandsome's Avatar
Default RE: Transmission Clutch Noise
I agree that the noise is caused by a worn out throw out bearing. The throw out bearing has some sacrifical material stuck to a metel donut so that when the throw out bearing engages the clutch bearing surface there is no metal to metal contact. I bet what you are hearing is the metal to metal contact becaause the sacrifical material on the throw oiut bearing has been reduced to nil.
Old Jun 6, 2007 | 08:18 PM
red's Avatar
red
i have 87 trk with only 60000 on it and it makes whining noise sometimes but not effect anything
350ZNtmare
Nissan 350Z / Fairlady
Oct 24, 2008 01:21 PM
dcogburn
Dec 5, 2006 11:47 PM
chriscouch1234
Sep 6, 2006 02:06 PM
ImShortJustDeal
Aug 19, 2005 12:58 PM
tripplsix
Jul 25, 2005 08:36 PM
