240SX Won't start
Old 06-29-2006 | 09:42 PM
bikeboy600's Avatar
Default 240SX Won't start
Hello Everyone,
I need some help! I have a 1993 Nissan 240sx convertible (automatic) The car will not turn over, battery checks out 100% ok. So I am thinking it is one of three things.
Bad starter
Bad Park/neutral switch
Bad starter relay
My question is, where is the park/neutral switch located? And how do I access it?
Thanks,
Old 08-23-2006 | 12:01 AM
ridgerunner1965's Avatar
Default RE: 240SX Won't start
seems like autozone.com website had a place on their website where you could look up the location of stuff like that.have yu tried jumping across the solenoid at the starter with a remote starter switch? would eliminate the starter and batt and cables.?
Old 08-23-2006 | 12:13 AM
NissanRacer's Avatar
is it cranking? It may be a fuse. always check the smallest things first.
Old 08-23-2006 | 12:16 AM
2dr_sentra's Avatar
Park/neutral switch is on the transmission.
Old 09-22-2006 | 09:29 PM
loomslarge's Avatar
I have the same exact car and you should invest in the factory manuals. They're expensive, but worth it.
DO you have lights or radio? If not, check the battery cables. remove from terminals and clean. That'll do it I bet.
Good Luck!
Old 11-24-2006 | 05:00 PM
Burnnout's Avatar
Fuel Pump relays are a common failure in 240's..... would lookin into that.
  #7
Old 11-29-2006 | 01:32 PM
dickswain_90's Avatar
try looking at the ground for the battery or the starter, make shur the are clean and tight.
i had the same thing happen to me.
-DICK-
chris g
03-03-2006 03:27 AM
clroyer
Nissan 300zx
12-24-2005 02:09 AM
rm777
Nissan Quest
12-03-2005 05:28 PM
wmartin
11-25-2005 07:12 PM
RichG
09-26-2005 10:42 PM
