oil leak 200sx
Old Jul 16, 2006 | 03:43 AM
u2shibby@yahoo.com's Avatar
Default oil leak 200sx
anybody know about any problems with an oil leak on a 200 sx. It is around the belt and alternator. I think it loses most when driving it. It is shooting on the belt and getting all over I can't pinpoint it. But it is there. the car has 120000 miles it is 2.0L anything something. let me know thanks tim
Old Aug 21, 2006 | 05:05 PM
AdriloverSR20's Avatar
Default RE: oil leak 200sx
You might want to check your valve cover gasket. you might need a new gasket and most probably that will be the problem...
Old Aug 21, 2006 | 06:17 PM
2dr_sentra's Avatar
where your talking about i would imagine its the v/c gasket, if so when changing it put paper towels in the plug holes to soak up the oil that is going to leak out then removing/replacing it.
Old Aug 22, 2006 | 09:21 AM
ridgerunner1965's Avatar
not sure if the 2.0 is the same as the 1.6 but i had 2 1.6 engines with what sounds like the same leak. it was the crankshaft seal behind the harmonic balancer. had a heck of a time diagnosing it tho. i purchased a ultraviolet leak detecter fron jc whitney and found it easy then. the first car i had the leak on i think i may of caused it by tightening the belt to tight. let us know what happens.
jdydvd
Sep 27, 2006 10:56 AM
rromano
May 1, 2006 03:16 PM
sporkhey
May 1, 2006 11:21 AM
bwilbert
Feb 13, 2006 09:21 PM
asdfghjkl
Feb 3, 2006 08:11 PM
