98 Sentra Oil Leak and weak engine etc
Old Jan 23, 2006 | 09:24 PM
asdfghjkl's Avatar
Default 98 Sentra Oil Leak and weak engine etc
My 98 Sentra has 100,000m on it. It has had oil leakage problem for a long time - the leakage happens in the main tank area bacasue I can see some oil close to the alternator;and I also found a lot of black dirts at the end area above muffuler. Garage told me there were dirts because the engine was weak and would cost $1,000 to rebuild the engine. The oil leakage would cost $600 to fix. Any suggestions as far as whether worth reparing it or how to fix the car? Any response will be appreciated. Thanks!
Old Feb 3, 2006 | 08:11 PM
Default RE: 98 Sentra Oil Leak and weak engine etc
on those 1.6L on the sentra the crank seals like to go bad around that mileage cause i replaced mine after i was going through two quarts of oil a week ill take a look at that first cause that could be your oil leak or possibly your valve cover gasket is leaking and getting onto your alternator.
pgr40
Oct 26, 2006 04:26 PM
Pinkley
Jul 2, 2006 03:09 PM
justinhustle
Jun 27, 2006 12:37 PM
sporkhey
May 1, 2006 11:21 AM
pablo_d
Nov 7, 2005 07:55 PM
