sr20det problem
Old Sep 14, 2007 | 07:56 PM
jessyjames89's Avatar
Default sr20det problem
heyy. the idle on my sr20 is fuked when i slow down from 2nd to 1st gear it stalls and when its just idleing it nearly or does stall.... could someone let me know what that is and what i can do to repair it? and i got black smoke from the catback. these may be stupid questions to some but i dont know what it means im here to learn thanks
Old Sep 22, 2007 | 05:09 PM
Default RE: sr20det problem
check your idle air control and i believe the sr20 iac valve is adjustable like my rb26also the black smoke means your running rich so check your fuel psi and check your fuel psi regulator your fuel psi should be around 40psi +/-5 also check for any vacuum leaks and intake leaks around the maf.
Old Sep 29, 2007 | 01:33 PM
driftking's Avatar
I have the same problem. Where is the IAC and how would I adjust it? I also thought it could be a vacuum leak but i have not found any.
Neil
Jun 1, 2006 07:10 PM
chense
May 26, 2006 12:41 PM
darren
Apr 20, 2006 12:16 AM
HXC_Nismo
Jan 2, 2006 09:09 PM
Neological13
May 29, 2005 01:49 PM
