Hot air
I have a '86 300zx non-turbo. Ive got a problem with hot air blowing in the car at all times, it doesnt matter if the air is on cold, hot or if the fan is on or off. Im planning on swapping the motor to a 350 cid chevy motor but I need some suggestions to fix the hot air until I can do the swaps. Thanx for any help.
hey man, first up i dont mean to sound negative but why would you buy an import then put a ****ty domestic motor in a perfectly good nissan chassis.
and to answer your question, First check your resistance on your switch. if its not that check the blower motor and see if its not shorted.
Hope i could be of some help.
ORIGINAL: baulkin
