My 300zx dies out on me often!!! need help!!!
Old Sep 5, 2006 | 04:53 AM
Mr_Yos's Avatar
Default My 300zx dies out on me often!!! need help!!!
1991 300zx non turbo
when i drive at high speed like 60mph plus my car would die out and sometime it wouldn't start untill like a couple days later usually 2 days it would crank over, but wouldn't start.
it also would die out when i floor it and sometime before it dies out it seem like the car is choking and the rpm would jump up and down like crazy.
I need to know whats wrong with it, plz help me!!!
Old Oct 16, 2006 | 11:27 PM
Zulater's Avatar
Default RE: My 300zx dies out on me often!!! need help!!!
i whould start by dong a fuel pressure check might be your fuel pump
Zulater's Avatar
Old Jan 9, 2007 | 11:57 AM
lakmflx's Avatar
Just like Zulater said check the fuel pressure/fuel pump. Also has the car had a tune up recently? Other things you might want to check if the fuel press and pump are ok is your MAF, fuel filter and fuel injectors.
Old Jan 9, 2007 | 05:52 PM
nismo89Z's Avatar
your MAF is usually the case in a nissan with this problem i've been there and done that. i would justgo to a junkyard with the best quality and look for one i've done it before and it fixed the problem quickly, and to this day i haven't had it anymore.
Old Feb 11, 2008 | 11:48 AM
NismoZ32's Avatar
I have a similiar problem, my car would die going down a shallow grade hill at around 60. My Z would just die and i would have to start mid hill or ride it down. I replaced my water pump and discovered the front gasket was worn out and the pump was shot. I replaced it and the problem was fixed for a few weeks.
Old Mar 11, 2008 | 10:00 AM
  #7
einar's Avatar
i had/still have this problem with my nissan skyline gts4, its a automatic and it would stall all the time. i ended up changing the engine since it started to smoke and the car didnt change gear at the rpm it should, i could rev the a/t to 7800rpm before it changed gear in 2nd gear, wich shouldnt happen.. pistons were burned already when i bought it... stupid as i am, the other engine i bought was a red top rb20det, i had to change to manual and rwd.. it then worked for a while but it keept overheating even with two extra fans! changed fuel pump since the old was bad, the engine behaves sluggish and wont rev past 3600rpm and when i try to adjust the screw behind the engine, nothing happens, when i adjust timing, the car stays alive at 1800rpm, but will give me a hard time starting it.. any lower and it would end up dying...
ive read here that if you have aftermaket filter, especially hks(wich i tought was great) it could damage your MAF.. my MAF is either very dirty or its done already.. and i can also have a lot more problems...
so now im gona change my MAF, and hopefully it works.. and get rid of my hks filter for a better one.
if anyone here knows what my problem could be, go ahead tell me!
Old Oct 4, 2010 | 05:27 AM
  #8
autodealer's Avatar
Looks like the car is loosing fuel pressure or lost it's timing better go to a mechanic and check it the the alignment of the timing belt is match.
_____________
nissan 300zx parts
dan2oaks
Nissan Quest
Jul 24, 2007 10:48 AM
sixshot
Apr 28, 2007 05:46 PM
brianwi11iams
Jan 5, 2007 06:16 PM
SS
Oct 14, 2006 07:23 PM
chase237
Mar 21, 2006 01:40 PM
