Help Please
I installed a new stereo in my 2003 frontier. I had to unhook the key switch and the off like for the passenger side air bad now the air bag light in the dash is blinking. Do anyone know how to reset it so the thing well stop before it drives me nuts..
thx
thx
well the fist thing to do is unhook the battery b/c alot of car company's tell you to do that so u can reset your computer but if not then goto a shop and see if they have a SNAP-ON scanner to rest that you dont need an AIR BAG scanner there is no such thing snap-on scanner will do the trick if the un hookin ur batt
I found this in another part of this forum. and it worked for me.
1. Turn ignition switch "ON".
2. After "AIR BAG" warning lamp lights for 7 seconds, turn ignition
switch "OFF" within 1 second.
3. Wait more than 3 seconds.
4. Repeat steps 1 to 3 three times.
5. Turn ignition switch "ON".
SRS is now in Diagnosis mode.
6. "AIR BAG" warning lamp operates in Diagnosis mode
I tried this several times with no luck. I then got out a stopwatch to time
the 7 seconds, (any watch will do with a second hand), and in between
repeating it every
time I removed the key from the ignition. This worked!!!
repeating it every
