Nissan Of Japan Other Models Elgrand, Presage, Serena, Lafesta, Safari, X-Trail.
Loss of power on a 2003 X-Trail 2.2Di
Old Mar 22, 2008 | 12:52 PM
timecreature's Avatar
Default Loss of power on a 2003 X-Trail 2.2Di
Hi
I have a X-Trail 2.2Di diesel which has just developed a fault. I am hoping for some advise.
The car is a 2003 model and has the earlier Di engine and not the Dci one fitted to later models.
The car drives ok at low revs and when working gently however above 3,500rpm with the accelerator fully down the car starts to juddering and the revs will not pick up. This is more noticable on hills.
The car will rev happily to the redline when out of gear and will achieve more than 3,500rpm if the revs are built up gradually on a flat or downhill.
I thought at first the turbo might be playing up although the car pulls quite happily on the flat from 1,700rpm to 3,500rpm so i am not sure. It seems to be more of a fuel starvation/blockage i don't know if this is symptomatic of an early turbo failure.
However i am no mechanic so any practical advise is welcome.
Old Apr 24, 2009 | 09:10 AM
budgie's Avatar
Default X-Trail fuel problem ??
[quote=timecreature;12425]Hi
I thought at first the turbo might be playing up although the car pulls quite happily on the flat from 1,700rpm to 3,500rpm so i am not sure. It seems to be more of a fuel starvation/blockage i don't know if this is symptomatic of an early turbo failure .
I have the same problem just starting on mine new fuel filter fitted by nissan dealer and it was fine for three weeks than it started again ?
any suggestions out there ???
Old Jun 4, 2009 | 06:34 AM
ribonzz's Avatar
I think the nissan filter you bought did not fit in .. You might given a wrong filter by the dealer ..
nissanfan
May 3, 2007 10:26 PM
vanreez
Mar 30, 2007 01:09 PM
sleddog
5
Mar 8, 2007 11:32 PM
mr dakine
Jun 20, 2006 08:37 PM
esdsix
8
Dec 21, 2005 08:12 PM
