91 se stalling flushin & rear manifold ??
Old Sep 10, 2006 | 07:16 AM
tikuninc's Avatar
Default 91 se stalling flushin & rear manifold ??
First off let me say thanx for this Forum being here... Finally got a Max , glad to do it ... always said I would own one...sick of driving stick... loved this auto back in 95 Bosses car so u know it got DRIVEN!!!!!!!
Ok.. 143k SE just got it for 500$$. sitting for 6-12 mos, it was second owner in great Exteior/Interior Condition...Little spots of rust , no undercarriage rust even .. Car started right up !! Guy said he changed tranny two years ago....also has a slight stallin g problem....did it twice 2night , just paused out on 42nd street@@ but started right up. again... guy told me he had this problem....pointed everything out.....Basically cleared himself in case of any lemon law stuff....even said two differnt mechanics could not figure out the problem....what i do know is this.....
1. the neighbor said good luck!!!
2. this was after I had asked him ..how long it was sitting
3. his response was ...1 Week.. ;- o
4. tires were at 20- psi , X2
5. there is a new outer belt..
6. radiator has small krack on top ...
7 At some point and this is probably when he stopped driving it......it blew rusty water all over the engine and trans......
8. ive put 50 miles on it,,,,ligtly and only changed plugs pcv air
9. Runss great tranny shifts smooth and is red...
10 So thanx for reading....
any tips on Corrrect BAckflushing or do I need to and rear manifold should I do anything else while Im at it...I will put the funds into this car if I can drive! it to 225K
any nyc, beers on me!
Old Sep 10, 2006 | 11:46 AM
reiska's Avatar
Default RE: 91 se stalling flushin & rear manifold ??
- rear manifold, wassup?
- rad: dont drive if coolant leaks, risks gettin air bubbles/ head warp
- coolant splash causes glycol to spread out:
A. Water vaporizes and problems vanish when all is dry, BUT microscopic glycol chrystals will remain, sit in any crack. When weather becomes humid, chrystals suck water, expand and cause electrical shorts = stalling - Return to A.
- it has VGE engine (or VE30DE)?
- misc stalling problems, go through link pages, clic below
Old Sep 11, 2006 | 08:37 PM
tikuninc's Avatar
vg30(E) engine...
i meant rear exhaust manifold....
also I put a after market radio in it with correct harness but no sound at all from the system......
Old Sep 12, 2006 | 03:00 AM
reiska's Avatar
yes, the manifold problem is leak? Needs new studs, gasket
Old Bose system loudspeakers have amplifiers, your new aftermarket has to be compatible (or bypass amp wiring at speakers)
Old Nov 16, 2006 | 12:35 AM
kushyboy07's Avatar
I Have a 1990 Nissan Maxima and I put in A new Head unit. when i installed the head unit their was no sound from the front speakers. When i put in new speakers they worked fine. I think that your speakers are just completly shot.
Munchkin1
Mar 19, 2006 05:45 AM
blackmaxi717
Mar 16, 2006 07:33 AM
dwj119
Nov 22, 2005 02:14 PM
NissanJTB
Oct 31, 2005 11:27 AM
studiocap
Aug 8, 2005 08:41 PM
