Circulation fan
Old Jul 19, 2007 | 12:27 PM
Doug's Avatar
Default Circulation fan
I have a Maxima SE 1998
Just recently my circulation fan quit working on speeds 1, 2, 3 but works on 4. I checked the main fuse box, all looked good. Any ideas how one speed works and three don't?
Thanks
Doug C
Old Jul 19, 2007 | 01:19 PM
Default RE: Circulation fan
your blower motor resistor is bad it regulates the speed of your blower and when they go bad it has a fail safe to work only on high.
Old Jul 19, 2007 | 01:25 PM
reiska's Avatar
If u mean cabin fan, it has a 'low speed resistor pack' on AC box wall behind glove box. Smtg wrong there... see arrow pointing ... inset is the squirrel nest (insideview) which should be vacuumed while there
see http://www.cardomain.com/ride/748507/7
Old Jul 19, 2007 | 04:12 PM
Doug's Avatar
I appreciate the responses. it sounds like the resister fan it is. On the web I see something that is described as the blower resister. Do you think a person like myself who has little to no mechanic backgroundcan replace it?
Thanks again
Doug
Click to Enlarge
#R2032-178006
Blower Motor Resistor
$37.95
Vehicle:
1998 Nissan Maxima 3.0 SE
Fits Engine - Chassis:
VQ30DE — A32
Description: exc. models w/ automatic climate control
Year:2/1994-3/1999
Estimated delivery time for standard shipping: 2 to 3 days
Doug
Old Jul 20, 2007 | 12:19 AM
reiska's Avatar
The resistor has two screws, connector. If u know which screwdriver end faces the screw, do it just turn... First tst is glovebox removal ... Note: It also may be loose connector, the fan sw.
I started to repair my own after a imbecile mech ripoff, catastrophic failure on highway ... luckily survived. Then I decided that I can ruin my own, lots cheaper. Then started buing tools: its rewarding to get it going, even when 'all' say you cant. Just decide youll make it, dont give up after catastrophic failures: youre still above mechs like that.
Old Jul 28, 2007 | 09:05 AM
juckerf15's Avatar
The resistor looks like a 3 inch by 3 inch flat card (like a printed circuit board).
I pulled mine out and bound a corroded solder connection on one side.
I cleaned it off and re-soldered the connection. It works fine now.
DownHiLL
Mar 31, 2007 05:08 PM
CaroIe
Jan 19, 2006 10:41 PM
darjenkins
Jan 5, 2006 11:09 PM
steve300zx
Sep 20, 2005 06:31 AM
macacc
Aug 15, 2005 04:01 PM
