exhust problems ! help!
Old Nov 20, 2005 | 11:27 PM
RedfoxXx's Avatar
Default exhust problems ! help!
so i put a bolt on warp speed exhust on my 95 maxima tonight
my chekc engin light came on and its acting verry odd
do i need something to fool the computer
the O2 sensors are in place, but teh Pre catts are gone
any thoughts?
Old Nov 21, 2005 | 08:26 PM
Brad Starkey's Avatar
Default RE: exhust problems ! help!
First, I suggest you read/have it read for codes. See what the computer thinks is wrong. If it says you have a bad O2 sensor... there you go. Or maybe it's something unrelated. You never know. Anyway, is it possible you damaged the O2 sensors when you changed them? Could be the missing cats are causing your problem too. Taking them off would cause a change in exhaust back pressure, which could change your mixture enough to possibly trigger your light. If so, I guess you could ask your local speed shops how to get around it. Also, did you make sure you didn't leave a wire or something disconnected (like maybe the 02 sens.) somewhere when you installed your new exhaust? It might pay to check it again, just in case. (Hey, it happens!) So like I said, read it for codes first. That way there's no guessing.
Brad
scollier
Jan 1, 2010 04:14 PM
tehhammer4200
Jul 20, 2009 09:23 PM
dsantos25
Jan 27, 2007 08:00 AM
MKE Maxima
Jul 2, 2006 11:11 AM
supersporttruck
Apr 7, 2006 08:42 PM
