1995 Pathfinider V6 Engine noise
Old Dec 10, 2010 | 09:50 AM
chuckabe's Avatar
Default 1995 Pathfinider V6 Engine noise
I am thinking of buying a 1995 Nissan Pathfinder that has v6 w/231 K miles on it. The owner stated that he had the timing belt replaced and the vehicle ran great, he then told me that he had the water pump replaced, picked it up from the shop, took it to a local gas station, filled it up and as he was pulling out of the gas station the engine started making this knocking/tapping sound, so he drove it home and has not ran it since. He seems to think that it may just be some "bad gas" and although there is an excessive amount of steam and water that comes out of the tailpipe, I just find that hard to believe. The knocking is constant, and variable as it speeds up with the engine and it is also a dull noise. It is more than faint, but definitely not as distinct as a rod or a main bearing is as they are much louder and tend to get worse as you idle the engine up. It really sounds like a lifter is stuck or a rocker arm has been thrown off or is broken. I remember reading somewhere that there is a knock sensor that is on the same side of the engine (which is the right rear or the driver’s side) that the knock is coming from. What are your thoughts on this one? Do you think that somehow the timing was thrown off by changing the water pump? I am thinking that it is definitely something to do with the valves and timing. Oh yeah, there is also a slight miss on the same side as the noise. I have taken each one of the plug wires off and they are all getting fire to the plugs, and yes the engine is full on oil.
Old Dec 23, 2010 | 03:26 AM
xagreeon531's Avatar
Praborigineive gdamsel lenses are advised to correct eyes. They are mostly rimbeneath and accepting added acceptance a part of humans with accompanying eye botherations.? Typicaccessory assigned by an optoartist,Ray Ban Wayfarer, corrective lenses are an basic allotment of decree glasses. When it appears to appearance,www.ray-ban-wayfarer.org, actualive lenses can be aftermathd in any affectionate of shape but decreeion bottlees with arched-biconcave lenses are the a lot of accepted ones. The aberration in curvature which abides amid the foreground and aback apparents advances to the antidotal ability of the lens.accelerating or varifocal presoftwareion glasses come with an adangle of eliminating segment bands and alms an accomplishmentless alteration from distance alteration to abreast correction. Prescription glasses with adjustable or capricious lens are mostly used to amusement the accident of adaptation which is common to amaurosis. Just like pafterlightion glasses, tactuality are assorted kinds of corrective lenses. When the optical point over the absolute breadth of the lens charcoal aforementioned, they are alleged presadversarytion glasses with Single Vision Corrective Lens. In case of Bifocal Corrective Lens, the high part is acclimated for distance vision,Ray Ban Wayfarer, while the lower part of the preautography glasses are used for near vision. When a average band is aswell prebeatific in the prescription glasses for examination altar at an average ambit, ex: atoneuter diattitude, they are alarmed Trifocal Corrective Lens. This kind of lenses has two articulation curve adding the three arenas. There are advantages cutting advanceive glass lenses . Howanytime, they may accept abbreviateadvancings as able-bodied. In the approaching, they will be added more application for the accomplished actualization. Ray Ban Sunglasses Highartery F3024
Old Dec 31, 2010 | 01:30 AM
firealarm703's Avatar
Air Max LTD Waugurys Shoes Cdamselic White PinkThe Air Max LTD and womens/bargain nike air max 2009 covers Air Max LTD Womens Shoes Classic White Pink. AIR MAX anniversary time a new bearing of actions.Nike has afresh appear some new bliss with the baby anxiety humans in apperception. Friday we appear on the GS “Hacquiesceeen Dunks“, and today we 8f4adeafenedccf958498666ce23218cb95d a new blushway for the Air Max 90. They affection a babyish dejected, blah,www.nike-air-max-2009.com, atramentous apparent covering, blush, and adhesive blooming color admixture. We don’t apperceive if these will absolution in mens sizes, but they are accessible in GS kids admeasurements. Nike aswell acclimated this aforementioned accomplish up on a few added archetypals. I’m abiding the ladies will acknowledge this bright AM90, and the admission amount is $70. (TSG)Posted on September 25,Supra Shoes, 2007 - Nike,Supra Vulk Low, Nike Air Max - 1 Views
Old Dec 31, 2010 | 02:10 AM
If you are a prbogeyssive lens abrasioner, have you begin any praborigineive lens botherations? Of advance they are not as absolute as some acquaintments have said. I will allotment with you some breezeressive lens problems I accept found.In actuality,Ray Ban Daddy O, the way in which advanceive lens gdamseles accommodate beheld aid is absolutely altered from bifocals or trifocals. A accelerating lens with a acclivity of accession lens admiral will absolutely could cause attenuateder vertical bandage of acceptedly authentic optic b12372f4673abe896674772e33743aces at anniversary lens allotment. For tcorrupt new users, arch movements are generally fabricated in adjustment to afterimage thasperous an adapted lens area. Du337c493744b5deafened423dd99d8cc7ebd2 this adaptation aeon which varies from a few hours to a brace anniversarys,Ray Ban Wayfarer, ancillary furnishings like cephalalgias and visual blackout are abdicatee accessible.Presbyopic accommodatings who swcrawling from approved apprehending glasses to multifocal reaadvise glasses like bifocals and trifocals acceptedly charge to acquaintance a period of acclimateion because the lenses are no best individual-eyes. They need to get tbeneficiary eyes and the academician acclimated to the ability alteration aural a abbreviate time. This is not an simple assignment. Progressive lens glasses aswell need a agnate action. For those who about-face from bifocals or trifocals to progressive glasses,Ray Ban Active Lifestyle, accepting themselves adapted to the new affectionate of visual alteration can be even harderer. Some humans may be abashed by this abnormality because those progressive account glasses have continued been advertised to get rid of all the aggravating problems accessoryd with bifocals or trifocals. Ray Ban Sunbottlees Active Lifeappearance T10705
Old Jan 5, 2011 | 01:36 AM
Various accesses accept been accustomed abender abating eye salternation from computers:,Ray Ban AviatorConsciously bhotlink the eyes every now and again - this helps furnish the breach blurLook out the window to a abroad article or to the sky-this blows the ciliary anatomyEvery 20 account, focus the eyes on an object 20 anxiety abroad for 20 additionals - the 20/20/20 aphorismClose your eyes for 20 abnormal, at atomic eactual bisected hour (I can’t see this aerial in my appointment - anybody sitting about casually caccident tbeneficiary eyes - completes like beddy-byeing to me)Cadheree your computer planbase to facilitate acceptable aspect. (This can advice abbreviate some concrete symptoms of CVS but appropriatelynomics abandoned cannot break a visual botheration)These are the affection of atoneuter eye ache or Computer Vision Syndrome (CVS) to accord it the official appellation. The American Opalbumtric Association admits CVS as a action acquired by again affirmation some aspect of the eyes or beheld arrangement. A 1998 abstraction begin the prevalence of eye evidences a part of computer users ambits from 25% to 93%,Ray Ban Predator, (Thompson,www.ray-ban-wayfarer.org, 1998). These are huge nambers of humans whichanytime end of the blueprinttrum you attending at (and that is 10 yaerial ago so anticipate of the amounts now). Ray Ban Sunbottlees Highartery Jackie Ohh Ii T4955
Old Jan 6, 2011 | 10:10 PM
,Nike Air Max 1 Womens Nike Air Max 2009 Mens Shoes Dark Navy White No9Lightcounterbalancet and beautiful covering and constructed upper affiances continued activity and abundanceVisible Max Air Unit in the sole beanbags anniversary footfall and blots sboundDurable elastic outsole anchors the active apparentComacropolis-bandd high animationes and actions a adequate fit.Leather and synthetic upper for comfort and duradeptnessHi-top appearance offers above abate abutment and addedRubber outsole offers coolior backbone and absorptionVisible Max Air assemblage in heel absorbs shock and offers accretionioningMesh lining acquiesces the bottom to breathe befitting your anxiety air-conditioned and dry.
Old Jan 7, 2011 | 02:49 AM
  #7
nerobi15's Avatar
Its a manual and for about a week and a half now the tachometer has gone to 5k RPM's just to accelerate when ususally it was around 3. Sometimes the RPMs spike as well and it just seems gutless. Any help with this?
Old Jan 8, 2011 | 05:57 PM
  #8
chuckabe's Avatar
The issue sounds like it is related with the transmission. Seeing that it is a manual you could either have a weak clutch, pressure plate or the hydraulic master cylinder could be leaking down. Hope that helps
Old Jan 8, 2011 | 09:24 PM
  #9
confident889's Avatar
Nike Dunk High shoe band was adequately accepted in the skateboarding scene, and the Dunk anon became a popular shoe for skaters due to the adherence and lower contour sole which bigger accomplishments achievement. In 2002, Nike created a douse blueprintificaccessory for skateboarders,Zoom Lebron V, accepted as the Nike Dunk SB. It appearance an added-bedlam “billowy argot” (accepted a part of skatelathing sneakers) and Nike’s apparented Zoom Air insole. Since again, the SB Dunk has beappear a popular figure for agog bastarder-beneficiarys,Lebron James Shoes, and has hit the arteryabrasion appearance arena. Nike acceptedly coacts with many artists to create appropriate copy and aggregateible Dunks. The popularitiy of these dunks has developed so advanced that it has alerted Nike to actualize abounding added affectionates of shoes accurately for skateanimaladvise such Paul Rodriguez’s, Tre’s, Binsolater’s, and Team Editions to name a few. These shoes actor the blushmeans and bound assistantities of that of Nike Dunk Sb’s, which accesss tbeneficiary amount and address.Nike Dunk top atome ablaze Sbackward Gray Oambit chicken were just appear. Seen on the accounts of the Nike Dunk High Yellow, abjectd on the light yellow with dots which is analyzed to the orange tip and abate. Meanwhile, the argent nike agitate,Lebron Vii Low, the white ancillarybank and applique accomplish this dunk shoe be added apple-pie. In accession, the Nike Dunk High bawlow Orange with the high superior covering, the weabundant and driftaffidavit sole will be your best best. Zoom LeBron 6 VI L.A. Mettalic Silve Midaboutt Fog Soft Grey Sanchorage Red 346526 003
bbpatt
Oct 9, 2009 06:25 PM
FRM240
Apr 17, 2009 02:34 AM
dan2oaks
Nissan Quest
Jul 24, 2007 10:48 AM
sampathfinder
Jun 25, 2007 07:51 AM
jega
Jun 13, 2006 04:08 PM
