2002 SE Steering Wheel Shaking...
Old Aug 21, 2007 | 07:46 PM
RJL766's Avatar
Default 2002 SE Steering Wheel Shaking...
...at highway speeds. I got the front end aligned and all tires balanced today (tread wear is even all around), but it did absolutely nothing. Does anyone have any suggestions as to what could be the problem? It starts at about 70, and the car has just under 70k miles. The car is in great shape and has never had any issues before. Thanks.
-RJL
Old Aug 21, 2007 | 07:50 PM
RJL766's Avatar
Default RE: 2002 SE Steering Wheel Shaking...
Just another note...the car still drives in a straight line. You don't feel it trying to veer off or anything like that. Thanks again for any help.
Old Aug 22, 2007 | 12:59 PM
well if it does it ONLY when braking its probably caused by warped brake rotors, if it does it at 35mph +/-10mph its probably a tire belt slipped and or separated tire, and if those are all ok then you possible have a bent wheel or a loose wheel bearing or a shop that has a wheel balancer thats not calibrated properly.
Old Aug 22, 2007 | 04:15 PM
RJL766's Avatar
I forgot to mention that the tires were rotated, too, so I think that eliminates a wheel/tire issue, unless, as mentioned above, the shop I went to wasn't too swift. Should've just done the rotation to see if that fixed it in the first place...would've been free!
Old Aug 24, 2007 | 04:57 PM
deeznuts's Avatar
how long have you had this problem? did you just recently replace something or hit something in the road? what is your tire press set at? recheck your balance, using a machine that also will measure road force vibration.
Old Aug 24, 2007 | 09:19 PM
RJL766's Avatar
This is a recent problem. I haven't done anything to the car. I actually drove it on a 100 mile trip with absolutely no issues, but then this shaking started the next time I used the car. It's in good shape, no problems except this one. When the car is off and I rock the steering wheel back and forth, there's a clunking noise coming somewhere in the steering. I had my girlfriend rock the wheel so I could look around underneath, and the whole linkage is vibrating everytime I hear the noise. I can't see it move, but I can feel both tie rod ends vibrating...not the greatest way to describe what's going on, but I'm trying...This can't be a balancing issue... I hope it is...its the cheapest fix!
stupidfast
Aug 1, 2008 08:20 PM
jdydvd
Jun 4, 2008 08:38 AM
qutee72
Nissan 300zx
Aug 14, 2007 10:19 PM
ORAZION
Jan 12, 2006 04:40 PM
MdNascarFan
Nissan Titan
Jun 29, 2005 06:56 PM
