98 Pathfinder Temp control problem???
Hi
I have a 98 (03/98) Pathfinder SE with a temp control problem. When I select full cold I get full cold when I turn it to the next detent towards warm it goes to full hot. I have replaced the temp resistor in the heat control panel and no change. The fan/blower operates normally. Im not sure what the next step is?
Its seems some problem in the temperature control system, as u have changed the temperature resistor too it is not helpful, so just go to a shop to get ur problem solved.....
I figured it out with help from a very experienced technician at my local Nissan dealer. There is a temp sensor located below the steering colum and to the right, behind a small grill. This had become disconnected. It was a simple 5 minute fix.
peanut58
Jun 21, 2007 01:09 PM
Reesifert
May 3, 2007 12:36 AM
gatorgar55
5
Dec 24, 2005 12:45 AM
98, contol, control, heat, hot, increasing, issues, nissan, pathfinder, problem, stuck, temp, tempeature, temperature, trouble
