thermostat location
Old 05-14-2006 | 05:03 PM
morenorob's Avatar
Default thermostat location
I need to replace my thermostat in my 1999 Pathfinder. Where do I find it?
Old 06-13-2006 | 01:49 PM
lpazdiscgolf's Avatar
Default RE: thermostat location
Since my wife's '99 had a overheating problem I had to locate it also. If you follow the lower radiator hose up into the engine you will see a triangular thermostat housing that bolts on with 3 bolts. You have to remove a few things to get to it and it doesn't look like the piece of cake it was on older cars. My wife's PF actually had low fluid due to a leaking upper hose and once I replaced it and filled the fluid up there doesn't seem to be a problem anymore so I didn't actually have to replace it. Get a Chiltons manual and it shows some good pictures on how to do this though. Can't believe no one else bothered to answer this.
manotass
Nissan Quest
11-29-2006 11:42 AM
hazeyez
09-09-2006 02:53 AM
dsmattes
06-30-2006 01:17 AM
youngpit
06-21-2006 09:24 PM
jimbob58
03-12-2006 04:03 PM
