BUILDING A 1.6
Old 09-26-2006 | 02:56 PM
SUNNY1.6's Avatar
Default BUILDING A 1.6
I NEED TO KNOW WHAT ENGINE CONPONENTS I COULD USE IN MY 1.6 SENTRA. MY GOAL IS TO MAKE A N/A ENGINE AND HAVE AROUND 200 HP.
Old 09-28-2006 | 05:26 PM
2dr_sentra's Avatar
Default RE: BUILDING A 1.6
ORIGINAL: SUNNY1.6
Unless you use alot of spray, youll never see 200hp in a GA16DE.
They make around 130whp with alot of mods.
Old 11-09-2006 | 05:00 AM
hendricks152003's Avatar
Hot Shot makes a turbo kit for the GA16 motor it says it will add 80 HPs which will get almost there and thats with a stock motor. upgade the injectors and add turbo pistons and a good set of cams you should be able to up the boost and get any where from 200HP to 300HP
Old 11-09-2006 | 07:02 PM
2dr_sentra's Avatar
ORIGINAL: hendricks152003
He said he wants to make a N/A GA16DE make 200hp. It will never happen.
ORIGINAL: SUNNY1.6
Old 11-24-2006 | 04:47 PM
Burnnout's Avatar
It's possible ... but not worth it .... I would reccomend investing in a SR20 motor... much better platform to build on.
Old 11-24-2006 | 05:27 PM
2dr_sentra's Avatar
ORIGINAL: Burnnout
Yeah it is a much better platform but even with a N/A SR20 motor is still hard to make 200whp...
If he wants a good N/A street set up, get a JDM 10:1 motor with C series cams form JWT, Gen6 header, 3 inch exhaust, UR pulleys, 19* timing, CAI and he'll run low 14's all day.
And, for higher compression get SR16VE pistons which i think make 12.5:1 C/R
  #7
Old 11-24-2006 | 06:29 PM
Burnnout's Avatar
Well going N/A on a nissan motor in general isn't the way to go .... for big power out of a 4 banger get a turbo.
  #8
Old 11-24-2006 | 07:47 PM
2dr_sentra's Avatar
ORIGINAL: Burnnout
well, i wouldnt say its not the way to go, cause the VVL motors are great for N/A setups, but most people like to boost there Nissans.
  #9
Old 11-25-2006 | 12:11 PM
Burnnout's Avatar
VVL motors are decent.... but on the average a turbo will deliver more power, faster.
  #10
Old 11-25-2006 | 03:27 PM
2dr_sentra's Avatar
ORIGINAL: Burnnout
VVL motors are more reliable than turbo motors, Some VVL's are running just as fast as DE-Ts
I forgot who is was but i seen on another forum VVL motors running high 12's, either way you cant loose.
