GA15i ignition problem
Old Feb 25, 2006 | 11:55 AM
biscuit's Avatar
Default GA15i ignition problem
I just installed a new JDM GA15 in my 89 Sentra. The problem that I am having is that the distributor is cranked all the way one way to compensate for timing I guess. But the problem is that when I go to set it on the marks it runs horribly but if I set it after the marks (towards the front of the car) it will run OK but not perfect. I have done a complete tune up with fuel filter and everything. I pretty much had to because the car sat for 2 years with a shot engine. So what could be causing this? I know the timing chain has not skipped a link because the motor only has 30-50k miles on it....but it could be possible. It was running REALLY bad until I switched the firing order around and it ran OK but not good enough..it misses here and there. I also just installed a new Accel Super Stock coil in it. Can anybody help?!
Old Mar 5, 2006 | 01:18 AM
hendricks152003's Avatar
Default RE: GA15i ignition problem
hey i thought is id let you know i just did that same swap. what i did what swapped the intake and exhaust manifolds and everything else on the head and put it on the GA15-B after i got it all together and put it it started rough but i played with the ignition timing and got it to run like a champ. so with your problem if your saying it runs but runs rough, (i had to swap the plug wires, put 1 in 4s and 2in 3s, then adjusted ignition timiming. now it runs like a champ.) i would try doing what i did. i kinda had the same problem untell i did this cause when i tried to start it it wouldnt until i did this....so good luck
Old Mar 5, 2006 | 01:22 AM
also what distributor do you have on it the GA15 or the GA16 cause i swapped the ga16s so that i can get a cap and rotor and not have to order one from japan. so let me know and i can help u out
mrspcy
Jul 25, 2007 02:31 PM
morphinemitt
Dec 29, 2005 06:36 PM
vx hatch
Oct 3, 2005 01:58 AM
Lady Gladrags
Sep 23, 2005 01:34 AM
DougsAltima
Sep 20, 2005 05:32 PM
