Electrical/alternator/battery issue, looking for help/suggestions/anything
Old Apr 21, 2006 | 11:40 PM
MKE Maxima's Avatar
Default Electrical/alternator/battery issue, looking for help/suggestions/anything
I own a 90-91 Maxima. Two days ago I came out to find the car dead. I jumped it and that worked fine but I stopped at a red light and when I pulled away my radio started cutting in and out and then the car started jerking back and forth and then it died. I jumped it again and took it to a mechanic thinking it was the Alternator. The mechanic hooked up the diagnostic machine to the alternator and it was putting out 14 volts , which he said was what it is supposed to do. He hooked up the battery and it was fine as well.
I drove the car again and after about 20 minutes it died as I was pulling away from a stop sign. I took it back to the mechanic and he thought maybe the alternator was heating up and quiting. He let the car run for 4 hours in the mid-day sun, it never died. He hooked up the diagnostic machine again and the was putting out 14 volts, and the battery was fully charged.
The only thing I can think of at this point is that there is a loose conection that is shorting out something, because of the stopping and going motion that occurs when I have to stop at red lights and stop signs.
Has anyone ever heard of a problem like this? If so, what did you do to fix it?
Old Apr 28, 2006 | 12:32 AM
Default RE: Electrical/alternator/battery issue, looking for help/suggestions/anything
did you take the mechanic on a test drive to show him what it does so he can have better chances of diagnosing the probleM?
Old May 15, 2006 | 12:50 PM
handyandhandsome's Avatar
As you car totally looses power and the mechanic did not mention a loose battery or alternator cable/wire, I would agree that there is a another loose wire/cable somewhere.
1. check the engine to body ground cable for corrosion and a tight fit.
2. check all the electrical plugs in the engine bay for integrity and that they are tight
jhallen978
Aug 16, 2022 09:43 PM
Prospector
Jun 3, 2008 06:36 PM
rwpage
Dec 29, 2007 08:35 AM
MKE Maxima
Jul 2, 2006 11:11 AM
