Maxima Won't start & can't get fault codes
Old Jun 6, 2007 | 10:18 AM
vedamoo's Avatar
Default Maxima Won't start & can't get fault codes
I have a 1990 nissan maxima that won't engage the starter, the check engine light doesn't come on and I can't get any codes from the ecu/eccs until after the check engine light is supposed to light up. I have asked around and so far have found no one with any ideas. Any help would be greatly appreciated.
Old Jun 9, 2007 | 01:35 PM
bigwilly529's Avatar
Default RE: Maxima Won't start & can't get fault codes
If the starter is not engaging it might be a bad starter solenoid which would require changing the starter. Could also be as simple as a bad ground or bad cable running to the starter. Check the power supply to the starter and go from there.
Stephenpnz
Feb 5, 2008 05:17 AM
thebigcheeser
Oct 26, 2007 02:51 AM
stereosushi
Off Topic
5
Nov 3, 2005 06:36 PM
tnvolfan
Oct 30, 2005 07:29 AM
stereosushi
Off Topic
Oct 9, 2005 05:31 AM
