Nissan Serena overheating
Old Mar 17, 2006 | 04:20 AM
sidyid's Avatar
Default Nissan Serena overheating
I have a grey import Nissan serena 2.0L diesel 4x4 1995 which was imported from Japan to the UK but we now use in spain.
The car started to bubble and gurgle and run hot a last week so I flushed the system through, but still had the same problem, I then removed the thermostat and it seemed to cure the problem untill this morning where it has started to bubble and gurgle again and running very hot.The Serena still drives, starts, and pulls very well but dos not seem to want to hold any coolant, as it is building up lots of pressure and blowing out.The Serena has only done 45000 miles and runs superb (too good to scrap)
any ideas anyone.
Mark
In sunny Spain.
Old Mar 17, 2006 | 05:39 AM
james171271's Avatar
Default RE: Nissan Serena overheating
hi it sounds exactly like what my serena did after taking mine to garage to check turbo and garage man reving it up the head gasket blew still drove but leaked coolant out the expansion cap when it was stripped it was leaking accross number 1 cylinder around gasket gasket cheap to buy £35 in uk but i cannot find any repair manual for the serena apart from autodata
Old Mar 17, 2006 | 11:03 AM
dragon52's Avatar
[&o]Bubbling, gurgling, building up excessive pressure in the cooling system, sounds like head gasket, unless you have cracked the head by adding coolant to the engine when it was too hot.
The correct procedure for this would be to slowwly add the coolant to an overheated engine while the engine is running.
Good Luck in sunny Spain
Don from Aus down under
spainmick
Nissan Of Japan Other Models
Aug 30, 2009 05:21 AM
jasvance
Aug 7, 2007 12:23 AM
Larry Hampton
Mar 30, 2007 01:32 PM
hazeyez
Sep 9, 2006 01:53 AM
hammond2277@aol.com
Sep 23, 2005 01:32 PM
