HELP!!!! WHAT HAPPENED!!!
Old Aug 22, 2005 | 05:36 AM
a3z0n0zx's Avatar
Default HELP!!!! WHAT HAPPENED!!!
I just got my timing belt, waterpump, and termostat replaced on my 1990 Nissan 300zx AT N/A. Now when I accelerate, theres a clicking noise. Also its hitting 4000-5000 RPM easily but it accelerates very slow. What is wrong?!?!
Old Aug 28, 2005 | 10:04 PM
mmmmnissan's Avatar
Default RE: HELP!!!! WHAT HAPPENED!!!
you should start by checking the oil level if it is low enough the lifters will make a clicking noise also check to make sure nothing is in the way of your pullies and belts. Check the A/T fluid level too that might be your accel problems. other wise you might have burnt clutches in your trans.
Old Oct 10, 2006 | 06:36 PM
mrelaxed's Avatar
did u get it fixed?
i just had the same set of things done to my '93. will be getting it back tommorrow, will let u know how mine's doing.
RaceY4SlipsTwice
Oct 30, 2019 10:14 AM
jmcs23
Oct 1, 2010 01:39 PM
salsarev
Sep 9, 2010 09:18 PM
