help...2005 won't start
Old Apr 10, 2007 | 12:02 AM
whitewolfz30's Avatar
Default help...2005 won't start
I have a 2005 Pathfinder and it won't start. It turns over fine, but won't run. Has 16K miles on it. I went to start it and slipped off the key in "mid-start". Now, it will not start at all. I tried to follow the owners manuel to start it with gas pedal all the way down for 5 seconds, then try again with foot off pedal ...proceedures from Nissan on starting if flooded. Is it possible it is just flooded and needs to sit awhile? Any help would be appreciated.
Old Apr 10, 2007 | 12:54 PM
Default RE: help...2005 won't start
no most fuel injected vehicles dont flood that easy, try to reset your ecu by disconnecting the negative battery cable for ten minutes and reconnect and try to start again unless your car is still under warrenty just take it to your nissan dealer and they would fix it for free since its 3 year 36k mile basic warrenty. also call the dealer first and see if they have a free roadside assistance towing before calling your own tow truck cause our dealer has the free roadside assistance. let us know if any progress
Old Apr 12, 2007 | 11:48 PM
Hey HXC, thanks for the reply. I just bought the Pathfinder earlier that evening, so this is a new to me vehicle...2005-16K miles. Turns out that the dealer had not programmed thetransponder in the spare keys. The set my wife had was good, but the other 2 sets were not programmed. I just wasn't aware that the vehicle would even attempt to start when a security feature was active. I got it started by resetting the vehicle with her key, and then went down to Nissan and they programmed the other 2 plus gave me an additional key (programmed) for my inconvenience. I guess if the starter had not kicked in, that would have clued me in on a "security issue". Thanks again though.
Old Apr 13, 2007 | 02:10 AM
no problem glad you got it fixed.
hollywood6318
Oct 11, 2014 11:29 AM
purebred
May 7, 2009 11:58 AM
AdamMisfortune
Nissan Titan
Mar 27, 2008 01:00 PM
clroyer
Nissan 300zx
Dec 24, 2005 01:09 AM
rm777
Nissan Quest
Dec 3, 2005 04:28 PM
