Nissan Fault Codes List
Old Dec 23, 2015 | 02:17 PM
igor2009's Avatar
Default Nissan Fault Codes List
Nissan DTC
P1105 MAP/BARO Pressure Switch Solenoid Valve
P1110 Intake Valve Timing Control Solenoid
P1120 Secondary Throttle Position Sensor Circuit Fault
P1125 Tandem Throttle Position Sensor Circuit Fault
P1126 Thermostat Function
P1130 Swirl Control Valve Control Solenoid Valve
P1135 Intake Valve Timing Control Circuit (Bank 2)
P1140 Intake Valve Timing Control Position Sensor (Bank 1)
P1145 Intake Valve Timing Control Position Sensor (Bank 2)
P1148 Closed Loop Control (Bank 1)
P1165 Swirl Control Valve Control Vacuum Switch
P1168 Closed Loop Control (Bank 2)
P1210 Traction Control System Signal Fault
P1211 ABS/TCS Control Unit
P1212 ABS/TCS Communication Line
P1217 Engine Over Temperature (Overheat)
P1220 Fuel Pump Control Signal Fault
P1320 Ignition Signal
P1335 Crankshaft Position Sensor (REF)
P1336 Crankshaft Position Sensor (CKPS)
P1400 EGRC Solenoid Valve
P1401 EGR Temperature Sensor
P1402 EGR System
P1440 EVAP Control System Small Leak
P1441 Vacuum Cut Valve Bypass Valve
P1443 EVAP Canister Control Vacuum Switch Circuit Fault
P1444 Canister Purge Volume Control Solenoid Valve
P1445 EVAP Canister Purge Volume Control Valve
P1446 EVAP Canister Vent Control Valve (Closed)
P1447 EVAP Control System Purge Flow Monitoring
P1448 EVAP Canister Vent Control Valve (Open)
P1464 Fuel Level Sensor Circuit (Ground Signal)
P1490 Vacuum Cut Valve Bypass Valve (Circuit)
P1491 Vacuum Cut Valve Bypass Valve
P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit)
P1493 EVAP Canister Purge Control Valve/Solenoid Valve
P1550 TCC Solenoid Valve
P1605 A/T Diagnostic Communication Line
P1701 Fuel Trim
P1705 Throttle Position Sensor Circuit A/T
P1706 Park/Neutral Position (PNP) Switch
P1760 Overrun Clutch Solenoid Valve (Circuit)
FULL DTC LIST YOU GET HERE
xr3dpill
Nissan Of Japan Other Models
Oct 4, 2009 06:58 AM
Stephenpnz
Feb 5, 2008 05:17 AM
Xterror
Nissan Xterra
Dec 13, 2007 07:03 AM
vedamoo
Jun 9, 2007 01:35 PM
rodccar
Mar 4, 2006 02:53 AM
