Valve Seal Replacement
Old Dec 6, 2005 | 11:48 PM
Judas's Avatar
Default Valve Seal Replacement
I need some expert advice... My 1999 SE is smoking a little.... OK..It's smokes like a $3 ***** at a Naval Shipyard!
It smokes a little bit on startup, and quite a bit on throttle... I have talked to a few mechanics and I am hearing that it may be my valve seals. If anyone has an idea on how much it would run me to have them replaced...for a fair price?
Thanks,
Old Dec 21, 2005 | 11:15 AM
reiska's Avatar
Default RE: Valve Seal Replacement
...SE is smoking a little.... ...
Glogged PCV can cause excessive blue smoke. Cleanit first, or replace 5$. Easy DIY.
Anythin may break 'anytime', but Nissan stem seals wear typically happens only after 300kmiles, 15yrs. How much you have to add oil per 1000miles?
Old Dec 22, 2005 | 11:36 PM
Judas's Avatar
Fair enough...
It's more of a whitish-grey smoke. Do you think that the PCV would do it?
It's not showing any codes though...
I have 88.6K on it so far... So far I have replaced the Plugs (with NGK Iridium), Ignition Coils (Mitsubishi type), Stillen (Short Ram Intake) and Stillen Exhaust...
It sounds great! But I am so pissed that I have to keep it under 3.5K rpm to keep it from smoking... at 4K rpm, it Growls!
Thanks,
Old Dec 23, 2005 | 01:29 PM
reiska's Avatar
"...whitish-grey smoke."
Typically white means steam. How is u coolant level? If u have to add water, then this points to a broken seal =coolant leak into the engine. (If this is the case, seek immediate replacement before engine heads warp.)
When u replaced the plugs, were they all looking good? If u still have them, compare to www.ngk.com trouble -chart.
Anyways, after PCV swap, I'd do a compression tst to pinpoint possible piston oil ring brkup ( plugs would show this also). Next go to a good known shop for diagnosis; a good mech can also listen&hear this condition. After diag, ask diff places for quotation.... Allowed discrepancy between cylinders is about 20%. (Gauge is '5$.')
Seek more info via clicking 'Favorite Links' http://www.cardomain.com/ride/748507/1
Old Dec 23, 2005 | 10:06 PM
Judas's Avatar
My coolant was just replaced about 2 months ago. It's definitely burning oil. I look at the smoke and see Whitish-grey...but the mechanic I talked to said it may be the valve seals.
The plugs shecked out fine.
I will try the PCV first and go from there...
Thanks,
Old Dec 31, 2005 | 11:52 PM
Judas's Avatar
Ok...New life has been breayjed into my Maxima! A new PCV valve has solved the problems (for now...)
But get this Crap...This evening, I was heading home from Wal-mart... and a stupid-*** Cop pulls me over for my stereo..
According to him, the distance whould be no more than 100 ft for being able to hear a car stereo! BS....right? What's the point of having 4000Watts of power and not crank it as I cruise!
Then, the ******* decides to check my tint too! I guess the 20% that I have is not legal! who'd a thought! I guess that 32% is the limit here in GA.
I am sure as hell going to court to fight this! I am hoping that he does't show at court so maybe I can get it dropped...
anyways...My evening pretty much sucked!
But at least my Maxima is running right again!
Old Jan 1, 2006 | 01:57 AM
  #7
ntxmotorsports's Avatar
4000Watts!! you're askin for it
what size subs you runnin?
Old Jan 1, 2006 | 02:33 AM
  #8
Judas's Avatar
I have 2 JBL 15's... I used to be able to use my trunk until I got them... lol
JFT26
Jul 22, 2009 10:37 AM
Reesifert
May 3, 2007 12:36 AM
etepsnewo
Nov 7, 2006 12:27 AM
chrissy02sentra
Mar 19, 2006 09:13 AM
gatorgar55
5
Dec 24, 2005 12:45 AM
