Alternator Question
Old Mar 17, 2007 | 04:46 AM
MaxRunner's Avatar
Default Alternator Question
Hey,
I am new here, I am a Toyota Owner (please don't shoot me)
But my girlfriend has a 91' Nissan Maximum.
Her alternator recently died on her trip to the local Supermarket.
I was wondering.
Can I change the alternator myself in the parking lot there?
Is it hard?
Does anyone have a write-up on it with listed tools with size needed?
I tried searching but the search engine couldn't find anything.
Thanks for your help in advance!
Old Mar 17, 2007 | 05:22 AM
reiska's Avatar
Default RE: Alternator Question
Replacement is relatively easy and fast... has to be done from below, after takin batt cable & pass side mud shield out. Then loosen/siconnect the belt tightener and take out the 13mm attachment bolt.The regulator plastic connector may be jammed real tight, use lube spray and yank/pry open with small screwdriver after pushin 'in' the connector 'lock'
I guess u may drive 'home' - 30min if your batt is full, with NO headlights, AC, fan...
I took 'some' pics; see page 23, click link below. Do check/clean also all connectors p5, 10, 14
http://www.cardomain.com/ride/748507/23
Old Mar 17, 2007 | 05:08 PM
MaxRunner's Avatar
Thanks,
I will take a look at it after the snow and ice melts around here.
Maybe even tow it with my 4Runner back to my place and get the work done there.
Old Mar 18, 2007 | 03:32 AM
reiska's Avatar
Note: IF there is no A/C, then theres lots space to take alt out from top just by openin the hood.
Old Mar 27, 2007 | 01:37 PM
gtcompscientist's Avatar
Don't worry about towing it back... I have changed alternators and radiators fans in parking lots before, it's not hard. Just kidding of course. If you can get it home, it will be less stressful.
tmoore
Nissan 350Z / Fairlady
Nov 24, 2006 02:44 PM
rattyZX
Nissan 300zx
5
Jul 28, 2006 08:00 PM
MKE Maxima
May 15, 2006 12:50 PM
Urgaynknowit
Feb 6, 2006 01:40 PM
Eastcoast
Dec 13, 2005 11:33 PM
